slow drying time
This dryer was given to me,. I was told it was slow at drying. I pulled the drum out so that I could check the elements, they are good. I then turn the dryer on and watched the elements come on then one went off after about a minute a little while later the other element cycled off then back on then off and on again, but only one element came on through about four cycles. What could be causing this problem? If it is a thermostat how do I know which one? Is there a way of testing these?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DPSR483EA1WW
GE likes to keep all tech info a secret so I cannot find specific info on this unit.
Below is a link to a fairly standard GE unit, it should at least give you an idea of how GE does things.
http://www.applianceaid.com/image/geediagram.JPG
Check inside your control console, often that is where wiring diagrams are stored.
[COLOR="DarkRed"]
This dryer was given to me,. I was told it was slow at drying. I pulled the drum out so that I could check the elements, they are good.[/COLOR]
When checking the elements, did you use a meter?
Also did you disconnect at least one side of the element you were checking just to be sure you were not reading an alternate/parallel circuit path.
[COLOR="DarkRed"]
but only one element came on through about four cycles.[/COLOR]
I am assuming you mean 4 heat/fabric settings.
Could be a bad thermostat, at least that is where I would start.
Nezt woyuld be the temperature/fabric selector switch.
You have 3 on the heater (Section 4 in the parts) and one on the blower (Section 1).
All of them should be 0 ohms at room temperature.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
