Spark at Control Panel
Turned the knob on the control panel to light burner and a spark of fire came out of the base of the knob. Does this mean that the control panel is bad?
I lifted the cooktop up and removed the 8 screws around the base cover, but could not remove the cover. Is there a method to removing the base cover
The burners and and the screws that hold them in place must be removed along with the knobs & Then the top should just lift off.
I removed the top an saw that one of the switches that control the turning ON an OFF of the burner had burned out. One of the wires was melted and no longer attached to the switch. Is this the swich metioned above?
That’s the one. The kit will replace all the switches so you should be good after replacing.
