Spin cycle noisey
My top load Maytag Bravo 300 isnt so quiet anymore. Very noisey when spinning. Parts diagram show two bearing sets and a required spanner wrench is this correct ? Somebody say the tub bearing is bad and is part of the tub. I think that is for front loader whos correct?
Kenny
The Maytag man was just here and said the tub bearings are bad will need to replace upper and lower with seals. He has requested auth from warranty company.
The repair guy came and replaced the shaft, upper and lower bearings and the seal. Noise all gone he said a very common problem. He advised me that the bearings have a 10 yr warranty. He also had to use a special tool to replace the bearings.
