Spin cycle noisy
The machine works fine but during the spin cycle it is starting to get loud like a bearing going bad. The tub spins freely by hand and there are no other issues with it.
Thoughts. Thanks in advance.
A noisy spin is caused by a bad bearing. It will only get worse. The best solution is to replace it.
[part]AP4028180[/part]
You would think they would make the bearing easy to replace w/o having to purchase a new tub assy. but from the looks of it that is not the case. $500 for a new tub assy. in a 7 y/o machine that costs about $800 new is not cost effective so now i will run it until it breaks and buy a new one.
btw i will not buy a Maytag again. :mad:
Thanks for the reply.
Yes…this was Maytag’s demise. Most people agree with your decision. I have seen techniques listed on Youtube of replacing just the bearing.
I’m going to e-mail Maytag and tell then what i think about their washers and why i will never buy one of their products again.
I feel better now. :slight_smile:
That’ll do a lot of good, since Whirlpool Corp. has owned Maytag since 2006.
If you continue to run it, you will blow out the speed control board, then it will be worthless. For about $75 in bearings and seals, you can fix it yourself, there are procedures posted to do this, or you can sell it and let others fix it. This washer is a fine mechanical design, much better than Frigidaire. If you lived in my area, I would buy it.
$75 is more like it. I don’t see a "search" tab here like other forums have. Do you have a link for the procedures?
Thanks.
Maytag’s response.
Dear Mr. XXXXX:
Thank you for visiting the Maytag web site. We appreciate hearing from you.
I am sorry to learn of the problem that you are experiencing regarding your Maytag washer. We can truly understand and appreciate your feelings concerning the problem you encountered and are sorry that we have lost favor with you. Maytag understands that valued customers, like you, are why we are in business. We sincerely regret the frustration and inconvenience you may have experienced as a result of this concern.
At Maytag, we are constantly working to improve our appliances, and it is only through feedback from customers like you that we are able to do so. We have documented all of your comments for review by our managers and engineers. Although this may not generate any further contact to you, our managers and engineers do regularly review our files.
You are a valued Maytag customer and we apologize for any inconvenience this concern may have caused.
We invite you to contact Maytag again either by calling (800) 344-1274 between 8:00am to 10:00pm EST weekdays or by emailing whenever the need arises. When calling please press the available option or stay on the line to reach a representative.
Sincerely,
Dawn B.
e-Solutions Specialist
Maytag Customer eXperience Center
http://www.Maytag.com
richappy said:
I For about $75 in bearings and seals, you can fix it yourself, there are procedures posted to do this
I searched the Appliance Database and found the info i needed. I’ll be calling Tony Tools in the morning. :smiley:
Thanks for the help.
http://www.neptunebearing.com.:confused:
