HI , i have a customer with a maytag atlantis , i am not sure how and where the spring motor pivot is installed ,is it installed before motor is put in or after .is it installed from inside or underneath ,do not know where its hooked up to, perhap a picture would help. thanks
Perhaps this will help
http://www.servicematters.com/maytag_library/docs/TDL-0012A-B.pdf
thanks alot
can you re attach the pic of the spring motor pivot please.
See attachment
Thanks a lot! I was about to call the May tag man because I was stumped. Thanks again
