squeaky belt
I have an electric dryer and it constantly squeaks. How to I get at the belt to tighten the tension?
Dear bicpoppa,
If you dryer squeeks you might take a look at the [CLICK HERE FOR THE PARTS BREAKDOWN](http://www.appliancepartspros.com/part_details.aspx?part_id=2142648"idler]rear drum bearing [/URL]and/or .
front glide bearingSince your in there you might look over the
[URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=109466)
— Begin quote from Gene;14327
The cause of the "F5" error code could be an intermittent contact on the power relay board or an intermittent oven temperature sensor (or it’s wire harness).
A burned spot on the power relay board makes this part a very first failure suspect.
The part reference #28 is not the oven power relay board. It is the downdraft power relay board. The oven power relay board has the reference # 29 on the [Model SVE47600B](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=635416&&model_id=43263"]body break down diagram[/URL].
Make sure this is the part with a burned spot on it.
[CENTER]The oven power relay board[/CENTER]
[CENTER][/CENTER]
[CENTER]The downdraft power relay board[/CENTER]
[CENTER] [/CENTER]
AP204871[LEFT]- The part number for the oven power relay board is [/LEFT]
[LEFT]Here are the break down diagrams for the Jenn Air range [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=635416&&model_id=43263)[/LEFT]
[LEFT]Gene.[/LEFT]
I had the same problem had a slight hum/buzz coming from oven removed control board and check the componts noticed some resdue arount the 47mf cap in the middle of board so i replaced this cap and it works now
Hi, does anyone know what color wire connects to tab E13 on the board
Thanks "Wdieckm"
I had an intermittent F5 error and checked the temp probe which was fine.
I also fixed my oven by replacing the 47uF Cap on the Relay Board. Of course this was after I replaced the Control Board ($250), which was fine.
Just be careful while de soldering the old capacitor. The traces on the PC board come up very easily.
