my washer keeps stalling… I keep turning it on and on and it just washes for a minute and then stalls.:mad:
Check the contacts on the timer, clean and reseat, but if that does not help things then a likely problem is with the control board.
These are extremely troubled models, one of the worst ever made and given the cost of the part I strongly suggest replacing it. You may be poorer in the short term, but you will be much happier for the long term.
