still no heat
Just changed:
Heat element
Hi limit thermostat
Thermostat
After the three changes, still no heat…Now what
I cannot tell from the info I can find on this unit whether it is a 240 volt dryer but if it is I would check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
The motor etc. runs off of 120 volts but the heater requires the full 240 volts.
If OK
If OK
Do this with the heater off and on.
