Kenmore dryer will not heat
Hello, my kenmore dryer will not heat I have replaced the heating element, hi-lo thermostat, thermal cut off, thermostat, thermal fuse, moisture sensor, and dryer still will not heat. Any suggestions on what to do next?:confused::confused::confused::confused:
Check the power.
The heating element needs 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
ok checked all power. One line in the cord was bad so I replaced it all power is good and dryer still will not heat! Could it be the temperature switch, or the control board??? I am ready to throw this dryer out and get a new one!! Any suggestions ??
