I have a Kenmore Elite dryer that just quit heating. I checked the thermal fuse in the fan housing and it seems okay. I also check the thermostat, thermal fuse and heating element and they all show continuity (NC circuits). What else should I check to see why it won’t heat. All other functions seem normal.
thanks,
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=110.64992300
You mention 2 thermal fuses so I am assuming you checked the thermal fuse and the thermal cur-off.
I would check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next try the diagnostics.
If OK
Unplug the unit and swap the motor and heater relays.
I believe they are the same but double check this before swapping.
