Hi, my front left burner - (the one I use most often, and the biggest of them all) is not heating up. I lifted the top, and the black "housing" that the coils plug into has a chip on one of the metal prongs. But also, the orange wires with the metal thing at the end, the metal part on the end of the wires was bent a little, and a little chipped. I am guessing that the "housing part is bad" The end of the coil/burner prongs look OK, but a little black on one of them. Could you tell me if I should look into the replacing the black plastic housing unit, or should I look at replacing the wire part? Please let me know, I am a mom who needs to cook! Trying to DIY to save a dime. Thanks!
Looks like the burner receptacle has to be replaced. It comes with the installation instructions. I would recommend to replace the heating element too to make the repair more reliable.
The part number for the burner receptacle is [AP3866514](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3030713&&model_id=250185&diagram_id=57746"]AP3030713[/URL]
The part number for the 8" heating element is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3866514&&model_id=250185&diagram_id=57746)
Here are the break down diagrams for the Whirlpool range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=57746&&model_id=250185
Thank you Gene! I really appreciate all your help!
