Stove top igniter not working on 3 of 4 burners
Burner 1 - gas goes on, makes clicking noise, sparks and lights - all good LF
Burner 2-4 - gas goes on, clicks, no spark but lights fine with match
There were only two burners out now the third one is out and have been living with lighting a match but want to repair.
Troubleshooting - connections to ignitor are tight, cleaned ceramic with tooth brush. Whole stove top to bottom was cold cleaned with easy off. Lots of baked on food grease. All dust blown out. Nothing else broken. No error codes if possible on this model. Also did a auto bake out.
Strange thing - Anytime I try to ignite the bad burners the good burner sparks and I have not turned it on. Also if I manually light the bad burners I can then only see the spark only when the flame is going.
I think it is the ignitor module since why would all three go bad.
