Stuck on quick clean cycle
Hi, my dishwaher is stuck on and will only run the quick clean cycle. I can run no other cycle. I tried resetting the the breaker for 30 minutes, no luck. Has anyone seen this type of problem before?
Thanks,
Steve
According to he tech sheet your quick clean cycle button is probably stuck.
Nat
— Begin quote from libertyappl;36364
Nat
Hmm, it’s a touch pad and the contact points are clean and free of moisture or corrosion, no way to get stuck, unless there is a micro switch on the control board that enages when the touch pad is depressed. I guess I’ll just replace the control board.
[SIZE=3] [/SIZE]
Not the control board, you need to replace the touch panel, you have a stuck key.
That’s right… Why didn’t that click in my head? Something about the idea of being able to just chop off the ground on a 115 cord made me think this, but something just didn’t click…now it does… Thanks…
I really do need to go dig out the ol’ electricity book one of these days before i fry myself…again :rolleyes:
Just a quicky note to let you know it works… 3 heavy guage wires clipped in with heavy duty alligator clips… It’s only there as a test line to make sure the motor runs and the heater works… Now i have it coiled up beside the 240 line where it can’t hard a fly unless it’s a really BIG fly with 4 inch legs and even then the circuit breaker it turned off. :eek:
Thanks again.
