SUD and F35 Codes
I have a Maytag 5000 series washer (MHWE500VW11).
Early this year it started to show SUD message. After research, changed the pressure switch and although it worked 1-2 times, again it showed the SUD message. From time to time by unplugging the machine and waiting, we would get lucky and the machine would start to work. But this was becoming exceedingly rare (more SUD and F35 messages). Then I changed the electronic control board (W10156258). Again it worked just once and as soon as I closed the top, it started giving the same messages (SUD and F35). I reopened the top and rechecked all the connections. I removed and reattached the tube to pressure switch (blew in it when disconnected) but no changes. What else can i do to fix this? Thanks.
