Got belt for Amanda lw6501w2 and instruction how to remove & install the belt. Difficulty on removing belt from the motor side since, cannot remove the pump.Tryed to shake the plastic pump but the pump doe not come off . Do you need to remove the plastic pump to remove and install the belt? Gave Amanda model # lw2501w2. But should be Amanda model # lw6501w2. Thanks for your help.
ted.
