Testing dryer with no heat
Hi Gene, I’ve read everything I can in the dryer forum but running out of ideas. Maytag Medc200xw1(Electric) only a few years old that won’t heat up. Heating element tests good at 10 ohms. Replaced all three thermostats and checked the thermal fuse. All test within range.
I have not tested any electricity, just resistance with ohm meter.
Anything else you can recommend that I can test?
Thank you
