Testing Gas Regulator/Kenmore
I need to know how to test the regulator on my stove. How do I know if it is bad?
What symptom(s) lead you to suspect a bad regulator? They rarely go bad.
i have gas coming into the house up to the regulator and i have no pressure on the oven or 4 range burners. someone suggested i check to see if the regulator was bad. what would be your suggestion? i’m afriad that till the middle of next month i’m looking for the least expensive route. thanks for taking time to reply. merry christmas
What I would check first is the condition of the burner diffusers. You can clean them with a straw bristle from a broom, or a tooth pick. Also check for kinked gas lines, where they’re accessible. Has anyone ever tried to lift the stove cook top without disconnecting the burners?
