My Electric Amana Dryer, Model LEA30AW does absolutely nothing when I push the start button. I have power to the outlet, but it seems as if the unit is getting no power.
The unit was working fine till I turned the main dial to a new setting in the middle of its dry cycle. It shut down at that point and I have not been able to turn it on since? I removed the door switch and found it to be working correctly as a normally on switch? Is it supposed to be normally turned on when the door is open and off when its closed? That seems opposite to me, but how could the component change its characteristics.
Please Help!
Stumped in Milwaukee,
Thai Joe
