http://www.ebzjmall.com/prom-dresses_c1124.html-A mermaid gown is a silhouette that is fitted through the bodice and the hips, and then flares out in to a fuller skirt at the knee. Mermaid gowns are usually made of fabrics that can hold their shape, such as satin, lace, or tulle, to emphasis the signature flared hem. It is a style that is made for a bride who wishes to make a dramatic grand entrance.
http://www.meetoobridal.com/mother-of-the-bride-dresses_c1123.html-A cocktail dress is a shorter-length dress that ranges from below the knee to two inches above the ankle (tea length) or touching the ankle (ballerina length). A dress can be worn to a semi-formal event. It is an evening dress that is identified by its length. It can be anywhere from above the knee to a few inches above the ankle. Cocktail dresses are worn for receptions, meetings and events that demand you to present in an outfit for the occasion. dresses must be without collars and sleeves. They are less elegant and less formal than an evening dress, but more elaborate and sophisticated than an ordinary.
http://www.bagshopmall.com/a-line-wedding-dresses_c1127.html-Feathered skirts are a major trend this year. Whether they are on a long, strapless gown or a short, cocktail dress, layers of feathers include drama and fun. The best way to wear a feathered skirt is with a tight top. For example, a strapless, bustier style neckline with a fuller bottom will produce balance. It is also much less risque compared to skin-tight cocktail dresses. The tiered, feathered skirts often possess a ruffled wire hem inside to keep them from getting flat. Similar to feathers are rows of alternating ruffles and rosettes. Again, these will work on dresses of any length.
http://www.donnamall.com/wedding-dresses_c1120.html-Mermaid Wedding Dress is probably the hottest wedding dress in 2011! The marriage day means an important day for all ladies. An appropriate style wedding dress shows their beauty much. A dress with tight bodice fishtail skirt would be like a nice choice for brides with curves designed to flatter your figure to be fully sexy.
http://www.donnamall.com/prom-dresses_c1124.html-When a prom is on the way, you may spend plenty of time looking for an ideal prom dress ahead of time. To start with, you ought to think about which style of dress will fit you perfectly such as length. The following content will tell you some tips about how to select the length of the dress which you can take as your reference.
