The Difference between Evening and Cocktail Dresses
http://www.meetoobridal.com/evening-dresses_c1125.html-Due to the fitted nature of a mermaid gown, you may need to think about changing in to a second dress for the reception. In case you are content to do a couple of ceremonial dances & then spend the remainder of the evening mingling along with your guests, your mermaid gown ought to be fine. But brides who plan to dance the night away will find it simpler to do so in a more forgiving silhouette.
http://www.meetoobridal.com/lace-wedding-dresses_c1139.html-An evening dress, also called a formal dress is a long flowing women’s dress usually worn to a formal affair. It ranges from tea and ballerina to full-length. Evening gowns are often made of a luxury fabric such as chiffon, velvet, satin, or silk. Although the terms are used interchangeably, ball gowns and evening gowns differ in that a ball gown will always have a full, flared skirt and a strapless bodice; in contrast, an evening gown can be any silhouette - sheath, mermaid, A-line or trumpet formed - and may have straps, halters or even sleeves.
http://www.bagshopmall.com/a-line-wedding-dresses_c1127.html-Feathered skirts are a major trend this year. Whether they are on a long, strapless gown or a short, cocktail dress, layers of feathers include drama and fun. The best way to wear a feathered skirt is with a tight top. For example, a strapless, bustier style neckline with a fuller bottom will produce balance. It is also much less risque compared to skin-tight cocktail dresses. The tiered, feathered skirts often possess a ruffled wire hem inside to keep them from getting flat. Similar to feathers are rows of alternating ruffles and rosettes. Again, these will work on dresses of any length.
http://www.sharonmall.com/beach-wedding-dresses_c1131.html-As the name suggests, the mermaid wedding gown has similarities with forms of the siren. So, the mermaid tails are seen in this type. The dress has of plenty of features to increase the knee or slightly below or above the knee together. It can basically be seen as a modified version. Petite ladies appear much higher than the dress of the situation, all the attention on the general appearance & kind of his superb extract.
http://www.donnamall.com/cocktail-dresses_c1126.html-Long. There is no doubt that for the formal occasions, the dresses had better to be long so as to generate a formal look. The long gowns appear elegant and charming and can highlight your femininity. When it comes to the prom, the dresses of floor length are the lovely choices. However, because of its long length, it will make a shorter body look non-charming and sluggish. In the event you are not tall , it is wise to keep away from the long dresses.
