The little Neptune that couldn't
:eek: Hi, I’m having a problem with my Maytag front loading washer, it will make some sounds but water will not come into the tub at the begining of thwe wash cycle. I tried the rinse cycle out some water came into the tub but the washer would cut off after about a 30-60 seconds:confused: .
I can not find out how to get into this washer to even check parts. Do I pry the top open, do something on the back or turn the silly thing upside down. I have a problem where the water does not stop filling even when washer is turned off. I have to turn the water off at the faucets. I was told it could be the water inlet valve or the pressure switch but it doesn’t do me any good if I cant get into it. Most people seem to know how to get into thier washers, but not me. Any help? Sarah
