The making of a holiday tragedy!
My oven no worky! When turning the oven dial to a temp. setting the red light for CLEAN begins to flash. Nothing happens but a flashing red light. However if I set the oven to clean the igniter kicks in the gas flows and oven heats up to the cleaning temperatures. I unpluged the AC power hoping maybe this would cause some sort magical reboot, but to no avail.
Could it be some module I need to replace. Or should I just boot this thing right out of the kitchen.
Any help would be greatly appreciated.
Thanks,Tim
You were right on the money fixxit. I found a defective micro switch broken in the closed position. (part description is latch switch)
I also found the model number of this Kenmore to be correct but it only comes up on the Sears site.
Thanks for your help,
Tim
Nice work, Fixxit!
kenmoretrash - Sorry this Kenmore model number didn’t come up on our site. We do carry parts for it though and (for the future) you can have our parts department get the info for you very quickly. Also, we’re adding more Kenmore models to an already very extensive database.
Bought this dishwasher 10-07. Hasn’t worked right since installation. about 2/3 of the time it just does not fill with water.Had new sink and faucet installed to so had plumber come back to check all connections. Plumbing is right. Is there a reset? I have read other sites about some dishwashers if opened before end of cycle, that is where they will start next time dishwasher is started. I know kids have opened before end of drying cycle. I have even opened it to add another dish when it is running without hitting the stop/cancel.
I have a fridgedaire frontload that did the same thing. It was the shocks, which there are 2. I also had the spring to break at a different time, when that happens the drum will drop with a loud noise and won’t work after that. The spring is fixable, if you ever have to fix it do both. A few months after we fixed one spring the other one broke. The shocks don’t seem to be a real big deal either. If you are handy at repairing.
