I purchased a new heating element,and a thermal cutoff kit… but the parts in the kit are not a match,the new part is not a direct connect,and uses a jumper wire,but if I do it according to the instructions,it leaves 2 wires from the harness that have no place to connect… does anyone know if this is how it should be using the new kit,and where would the 2 wires left in the harness connect to…?
Related topics
Thermal Cutoff Kit | 0 | 2191 | August 11, 2008 | |
Thermal cut of kit versus thermostat | 2 | 918 | March 16, 2014 | |
Trb | 2 | 1175 | March 15, 2009 | |
thermal cutoff kit | 1 | 1102 | May 19, 2010 | |
Help with Replacing Thermal Cutoff Kit | 6 | 12694 | August 16, 2008 |
