dryer wuld not start. replaced thermal fuse. ran or a day, now won’t start again.should i replace thermostat?
I had read in a previous blog, that it is recmmende to replace the thermostat when you replace thermal fuse because they usually both blow.
i replaced the thermal fuse and the dryer worked for a day but it has blown :eek: again
check to see by removing heater , held down by 2 screws ,if heater coil is warping and vibrating, touching housing, put your hand up housing to see if any foreign object is up there
