timer connector
How do you remove the female terminal from the plasic block connector? My wires and timer fried from a power surge and I can’t figure out how to remove the wires from the connector. I have a new timer and plastic white connector to install.
Given your power surge and the probably damage to the wires I think your best, safest and most correct thing to do is to replace the wiring harness.
