Need to replace timer, can someone give a hand with instructions? can send me repair manual timer section only? Thanks. my email rgg5@terra.com.mx
— Begin quote from mopar0;264091
Mopar,
Some instructions , as you requested .
First thing you need to do, is unplug the power cord.
Servicing Components in the Console
- Remove the two phillips-head screws securing the front corners to the washer top.(on the plastic end caps).
2)Tip the console back on the hinges that secure the top of the console to the washer back panel.
Removing the timer
There are two types of timers.
One can be identified by a plastic body, the other has a metal body.
Plastic Body
To remove the timer knob, push the knob in from the front.
At the back of the timer, pull the black tab out approximately 3/16", then pull the timer knob off the shaft.
3)Slide the dial from the timer hub.
unplug the wiring harness connector from the timer assembly terminals.
Remove the one(1) hex head screw securing the left side of the timer assembly to the console mounting plate. Then lift the left side and slide the tabs at the right side of the timer assembly from the mounting plate.
Metal Body
To remove the timer knob, push the knob in from the front and unscrew it from the timer shaft
Slide the timer dial from the timer hub.
Remove the two(2) hex-head screws securing the timer assembly to the console mounting plate.
Reverse the procedure and test washer operation.
Joe,
Thank you, I will proceed as you describe, let you knoe the outcome!!
Best Regards!
— Begin quote from mopar0;264191
Joe,
Best Regards!
Mopar,
You’re very welcome,
Look forward to hearing from you.
