Timer Not Advancing
Origial problem was timer would not advance and automatically shut dryer off. Replaced timer, but problem still exist. Dryer is an auto sensing unit and should advance the timer as clothes get dryer. Dryer heats properly on all tempature settings. Timer advances properly and shuts dryer off when running in timed air fluff mode.
Is solution to replace the Thermostat with part # AP4038076? Is this thermostat sensor actually a "moisture sensor"? If this is not the correct solution, can you provide the correct solution(s)?
