All functions appear to work. It fills, agitates, drains, and spins. However, it will agitate immediately upon starting to fill and adds water during the final spin cycle, thus leaving the clothes wetter when done. There are no unusual sounds. Any ideas?
— Begin quote from richappy;121768
I would check the water level switch. Remove the plastic hose to it and blow in it to clear it out. Check the other end where it goes into the tub, clear out any soap residue with vineger.
The entire hose is clean including both connecting ends. What next?
Does it act up on any cycle? To help further, I need the complete model #
— Begin quote from tyount;121581
I have the exact same problem. Did you ever find out the cause? Was it the timer? Thanks!
