Timer won't advance.
The timer on this dryer will not advance no matter what setting it is set to. I have checked the continuity on the timer, the multi-temperature thermostat, and the hi-limit thermostat, and they all check out OK. Where do I go next? Thanks for your help.
If the timer doesn’t advance, open the console and make sure there are no disconnected wires. DON’T TOUCH ANY WIRES OR CONNECTORS, UNLESS YOU FIRST UNPLUG THE DRYER… If nothing is disconnected, replace the timer. Here’s the part number. [part]AP4043236[/part]
