timer
I have to stand around to manually change washer cycles. Which part of the timer would need fixed? :confused:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GLWS1233S
If you are confident that it is the timer then the timer needs replacing.
Individual timer parts are not available.
