My washer stopped switching between cycles. I can set it on any cycle and it will continuously run on that cycle without switching to the next cycle. What part do I need to replace to fix my problem?
Sounds like the timer motor inside the timer is a problem. If that is it you will have to replace the timer. Here is the part.
