washer won't switch cycles
Washer will not switch to next cycle. I have to stop it and manually switch it. Is this a timer issue?
Thanks,
Conbar
Yes, most likely the timer. If you buy from APP and it doesn’t fix the problem, you may return it.
http://www.appliancepartspros.com/whirlpool-timer-3949339-ap3019158.html
Eric
