timer
[SIZE=3]replacing timer works for 30 days, 2nd timer replacing is not working ,what next?[/SIZE]
Here is a service manual which may help
[SIZE=3]http://www.servicematters.com/maytag_library/docs/16023110.pdf[/SIZE]
[SIZE=3]replacing timer works for 30 days, 2nd timer replacing is not working ,what next[/SIZE]
Does the above mean that you have replaced the timer twice?
Why was the first timer replaced?
Do the timers all fail in the same way?
What is the problem with the timer?
What have you done to troubleshoot the timer?
Where did you purchase the timer? It may still be under warranty.
Do you have a meter?
In other words need a better description/history!!!
The dryer never stop.
