Whining sound mostly during spin cycle…what do I check to determine part replacement, etc…
Hi.
Most likely there is a foreign object inside the drain pump. Take it out and check. You’ll be surprise when you look in there. You may need a new pump.
The drain pump [part]3363394 [/part]
Use the video clip for the instructions.
Here are the breakdown diagrams and Replacement parts for Whirlpool WTW5320SQ0 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
