transmission
please help!!!
my washer fills up. begins to agitate with each agitation it goes clank! clank! clank! at a rather slow process.then at the spin cycle.it wont spin but sound likes a high speed drill from hell really loud.the water empties but wont spin.
any answers ?
thank you
Hello.
From the clunky clank sounds you are describing I should point you to the coupling assembly. There is the chance it could be something ells but I would stick with coupling.
It’s located between the motor and the transmission.
The motor coupling AP3963893
On the diagram#3 position#13.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5141736
Please post the results and thank you.
