Hi,
I received the trim kit for the Whirlpool oven door. I can’t seem to get the glass and trim pieces to fit together. I followed the set of instructions posted from another customer but the trim just won’t fit over the glass. The trim pieces seem to be the correct size based on the old ones. Been at this for a long time and can’t get it to fit. Please help!
Have you looked at the help that is part of the part info.
Click on the picture of the parts a new page will open with more views and info.
Often there are questions at the bottom of the page, click on the question to get the answer.
Yes I have tried that and looked at the posting however it does not help me. Is there a special way to get the trime to fit over the glass. The pieces seem to be exactly the same except for the bottom where the new trim no longer has screws. I have the door totally apart. In what order do I put it together. I have tried several different ways of putting it together and the trim just doesn’t seem to fit over the glass.
Sorry but do not have any additional info than the following from the posts.
a 4 step process, insert the glass into the slot in the bottom of the top door trim/handle trim, insert one side trim in until flush with the door trim, then repeat for the other side, then insert and attach the lower trim to the bottom of the door liner with the 2 scews, the 2 end screws have been eliminated and there are plasic studs that insert into the openings on each end of the bottom trim panel
And
The dimples fit into the indentations on the trim piece. When the trim is secured, they will lock into place.
