Ultimate Care II - LEQ8000JQ4- doesn't run
Upon pressing "press to start" button, the motor doesn’t engage. The heating element heats up (in fact gets very hot) - but there is no sound other than the timer running (which you have to listen very carefully for). I tried to jump the thermal fuse, but no change (still didn’t work). I’m hoping it is the "press to start" switch and not the motor that is bad. How can I check, and/or may it be something else?
Thanks.
