understanding
ok dryer has absoutley no heat ,i replaced the coils the thermostats seem to be fine, the sensor gives me a reading and the ignitor works as well, though it only glows for about ten seconds than cuts off is this normal? know thee only things i have left to check are the thermo-fuse and the heating now are there any another elements i have to check for, or are these five main parts associated with the no heat to dryer
If there is nothing wrong with these five parts and the gas line is open then the problem is the gas safety valve. There is no way to test it.
  • The part number for the gas safety valve is AP2043480
I’m not sure how to test this thermostat. You have to check the wiring diagram. If the igniter continuity test shows the closed circuit then it’s good.
CODE F2EO POPS UP …AND THE OVEN SHUT DOWN AND KEEP BEEPING …CAN YOU HELP DO I NEED A CONTROL PANEL:confused:
Instructions on how to replace the buttons on the control panel on the dish washer door and required parts or any specific tools needed. our contact info is klrl@att.net or 512-423-6500. We have purchased the buttons and the control panel - we are hesitant to take it apart without any instructions. So far we have only found a diagram on the bosh site - nothing else. Please, help - your assistance is very appreciated.
Thank You
lambert labay
Lambert,
The file with instructions is attached to the reply.
