It drains but doesn’t spin (or agitate?) I replaced the Thrust Bearing Kit to no avail. Though when doing so, there was no room to fit either of the washers on. With just the e-clip I was able to turn it JUST to the first marker. Is that not far enough, that it’s preventing the spinning? Would trying to use a washer cause it to travel farther, or as I suspect, it wouldn’t even get as far as that first marker?
Other info: the belt looks to be in decent shape (washer has been stored for 5 years), and I put in on blocks and all pulleys and the belt turns during spin cycle but the basket does not.
Thanks.
