I have a Maytag Double Gas Oven. The lower oven works fine. All my top burners work fine. But I can not get the upper oven to work. The upper oven and the briler do not work.I replaced the igniter, but that did not fix the problem. I am not getting 120 volts to my igniter.
What should I check next to correct the problem?
Hi.
Get the access to the control board and locate contacts 1,2,3,5.
Using the multimeter check red and yellow to the ground.
You should read 0 volts.
Next turn the upper bake and check again(Red.) Then - broil, (Yellow.)
No power - replace the control board.
Control board 5701M576-60
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171002
Thank you. Post the results.
Simon.
Thank you so much. I followed your instructions and that was the defective part.
I will definitely use The Repair Help Forum in the future and order all my parts from Appliance Parts Pro.
