Double oven - top oven not working
I have a Maytag Gas Double Oven range, Model MGR6775ADQ, Serial 11494720EV. Top oven stopped working. Broiler in top oven works, bottom oven works. Replaced ignitor with no success. Had repair man look at it and he stated the “bake controller” was bad and could not be replaced. Looked on AppliancePartsPro.com and ordered part number 74011290 – valve bake, order number 6027337. Also ordered W10166969 – control electric, order number 6026448.
Made an attempt to install the valve and the part on the stove is different from the part I received. I did some additional trouble shooting and would like to send pictures and explanation. In a nutshell the only thing that does not work is the top oven, broiler in top oven works as does the bottom oven. When heat is called for in the top oven the ignitor has power in both wires going to it and the actual metal ignitor has power but does not glow.
Can you help? If not, I will need to return both parts.
