vbirkenthal
I need to know how to install a new door since my old one has stains that won’t come out because of the steam in the machine. I anyone could let me know what I need to do to replace it I would appreciate it. I have ordered the replacement door and it is on its way. Thanks!
Which part of the door, inner or outer, did you order?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110125
I ordered the outer door the old door has water like stains on in that will not come off so I am trying to replace the black outer cover since the dishwasher works great just looks bad. Thanks Vickie,
Outer thanks for your future help.
Vickie
Vickie,
Open the door. Holding the outer door from the under the door, remove the six T-20 Torx screws located three on each side of the inner door and two screws (#2 on the diagram).
Remove the outer door panel.
Remove the two screws secured the door handle and, using the same screws, install the door handle on the new outer door panel.
Great response times and really easy to follow instructions! Thanks again.
Vickie:):):slight_smile:
You are welcome Vickie. Keep us posted.
