Whirlpool
Ultimate Care II
LSQ9110KQ1
Over the last while is seems like the washer has developed a klunk that seems to be at the end of a cycle.
Now it seems to have two things going on.
Today is has developed a Whining noise. It only happens when the tub is moving.
Also, the tub is really starting to stop hard when you lift the door.
I think you’ll see what I mean in the video.
A whine and the slam.
Thanks guys - hopefully you can tell me what parts I need.
https://www.youtube.com/watch?v=wnWPXeN8r8U
Hi.
Saw the video, heard the noise :). The noise is coming (I’m pretty sure) from the drain pump. You probably will find a bra support wire inside the pump after you will take the hoses off. Make sure the pump is not damaged, replace if needed.
The hard stopping at the end of the spin cycle sounds like you may need to replace the clutch assembly.
Here are the breakdown diagrams and parts list for your washer
[MODEL]LSQ9110KQ1[/MODEL]
The drain pump AP2907492
The clutch assembly AP3094537
Good luck. Please keep us posted with the results.
Thank you.
Simon.
Thanks Simon - parts ordered - will update ASAP
