Washer making loud noises as spin cycle stops
As the spin cycle ends and the tub is slowing down/stopping the machine makes a fairly loud, repetitive thumping noise. I thought it might be the braking mechanism, but have read some posts suggesting other possible causes and because I just finished several other repairs yesterday, I wanted to ask questions before I blindly embark on another repair.
Here’s a link to a video so you can hear what I’m describing: [Tub Suspension Pads](https://vimeo.com/248875151"]https://vimeo.com/248875151[/URL]
FWIW, in person, the banging is a bit louder than it sounds in the video.
So yesterday I replaced the following, and for all I know may have caused this banging noise myself…
The spin cycle seems fast, steady, and a tad quieter now that I have replaced the suspension pads. But the thumping/banging noise is new. It wasn’t happening before I made the other repairs.
I’ve read Richappy’s sticky post on brake shoes. Certainly seems plausible, but still hoping I can provide enough additional info here to know if that’s my best bet.
I read a post suggesting the tub support and/or skate plate may be misaligned. Not sure how to verify as they "looked" aligned and slid smoothly on the new pads I replaced, but who knows?
Another post suggested that the drive block may not have been fully re-seated with the tabs properly in the designated notches. I was pretty sure I tapped this in firmly and properly but will double-check once I disassemble the washer again.
I would love any additional info on diagnosing this issue before I begin buying more parts and playing trial-and-error.
Thanks!
