My waher fills and washes ok but will not automatically go to the spin and drain cycle…I can manually advance to the spin and drtain cycle, then I also have to manually advance it to the off. The washer has been working perfectly, and is just a month over a year old but was moved from one house to another and this just started after the move???
Open the control panel and check the timer wire harness plug connection.
If there is nothing wrong, replace the timer.
- The timer AP3995038
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5213824
Thanks for your help…the plug is fine…I will order the timer…Peter
You are welcome Peter. Keep us posted.
