Jenn-air convection wall oven went completely dead after power outage. No clock, no lights, no error codes. Built in microwave above works fine. Both run off of same breaker. Does this mean the control board is shot?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JMW9527DAB
See the attachment for the wiring diagram
Not necessarily.
Looks like the microwave runs off of the L2 side of the line (red)
The stove control board runs off the L1 side of the line (black)
So I would check the power, first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
