wall oven
After self cleaning ended, oven will not heat up. everything else works. The control panel functions as if it is working, however the elements will not heat up. I have flipped the breaker but to no avail. Help
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rbs275pdb14
Sounds like the thermal fuse nay have blown (Item 37 in Section 1)
