warm fridge
I recently purchased an evaporator fan and motor from Appliancepartspros.com for a Kitchen Aid built in fridge with a bottom freezer. The motor was easy to place but the motor still would not kick on. I ran a diagnostic which indicated that the motor wasn’t responding (which I already knew). Any suggestions. The unit is a little over 5 years an is a KBRC36FKS00.
What was shown on the water filter status indicator when you ran a self diagnostic test?
Did you run it according to the service and wiring sheet?
Gene said:
The 5-2 reading means the compressor was off. You should run the compressor test again after at least 7 minutes interval.
Did you do it?
If you did, what was the result?
Perform all tests, described in the [manufacturer warranty](https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/d1677e8dd78477cc85256df0006cf458/$FILE/4317344.pdf"]service manual[/URL] to find out what exactly is wrong.
If there is something wrong with the compressor, it has very good [URL="http://shared.whirlpoolcorp.com/assets/pdfs/literature/Warranty%20Page%20-%202215851-W.pdf).
Gene:
I ran the test again and the compressor turned on. The indicator went to 5-1 so it’s OK. I am downloading the manual now and will follow your instructions. I will say though, that the freezer (bottom) is working fine. So the compressor is working. The fridge is cool, (41 degrees) but not the usual 35 degrees. So I think the problem may be in the evaporator fan relay (electronics) since the fan circulates freezer air to the fridge (top). The manual states that the service alarm beeps if the evaporator fan relay isn’t functioning and it isn’t. So there must be a problem with the relay. How is this fixed?
I have a Kitchen Aid mixer model KSM90PSWH that is not working correctly. On the Field Assembly stator there are two wires–one black and one white. At the end of each wire is a brass clip approximately an inch long and 3/16ths wide. The clip is curved and both clips are by the armature. Question: where do these brass clips attach? JG
Just replaced the control panel on the dishwasher and it has no power to it
