When the door closes, the "Washing" console light comes on and about 6 seconds later the pump motor seems to start. A few seconds later it
sounds as if water is going into the machine. No water is present. House
water supply has been checked and is OK. Water valve inlet inline screen
has been cleaned. 110V current directly to solenoid valve does not open
valve, however no power appears to be getting to the valve inlet (Part #
AP4366628 A new Cntrl-Elec Part4303742 (W10084142) was installed to
no avail. After approximately 1 minute the Washing Light goes out with
no further progress. It is necessary to shut off the main power circuit breaker
for a short period before the Washing light will come back on. Any help will be appreciated.
Contact: teedee1@optonline.net with any pertinent info. Thanks
