dishwasher turns on and off and now will not run for more then 1 minute, anythoughts from anyone would be appreciated. I think it is the electronic control assembly.
Could be a loose connection as well. worth a look.
Nat
That would be highly probability. Do all the LED’s lilght up with you push the corrisponding button? If you have a ohm meter you should be able to use the tech sheet to do some tests.
Nat
any time!
Nat
Had sears replaced seal on door and it still has forst on the door they were here two times I still have the same problem. door the doors have a heater in them ? Or is there a electronic part that is deffective. I have worked on frezers and Air Conditioners So I am not new to this. Can you tell me what may be the diffecive part ?
John Kloch jkloch@tds.net
